First let me explain on left side is folder with tasks, that goes the percentage of completition, and sum of story points.
If i have divided tasks to folders and have percentage, can someone explain to me,
what this image shows?
That tasks in "add new campaign step 1" are finished 82%?
If yes that it basically means that there are 184 from 1022 Story Points left
image2016-5-6 18:18:41.png
BUT
When i exclude tasks that are completed i get that there is 471 Story Points left
image2016-5-6 18:13:51.pngimage2016-5-6 18:18:48.png
The problem was that i haven't set the weight to story points.
Thanks for confirming!
Hello Davor,
Eugene from ALM Works here. Could you please send the screenshot of the progress column settings to support@almworks.com or open a ticket at jira.almworks.com.
There are a few additional options there that affect how the progress is calculated.
It's hard to say why you have these values without seeing these options.
Eugene
