Sub-Task Automatization
Markus
We would like that the parent issue gets moved to the next status once all the sub-tasks reached this status.
For example:
  • User Story - To DO
  • Sub Task A - To Do
  • Sub Task B - To Do
Once both sub tasks reach the status "In progress" the parent Task should also get moved to the status "In Progress" automatically or maybe with a pop up asking if the parent issue should be moved.
Do you know if this is possible?
Regards.
Dave Bosman [Realdolmen]
August 24, 2018 edited
Hi Markus.
You can do this automatically with automation for jira
https://marketplace.atlassian.com/apps/1215670/automation-lite-for-jira-cloud?hosting=cloud&tab=overview
The link is for the free version.
There is also a paid version with more functionality.
https://marketplace.atlassian.com/apps/1215460/automation-for-jira?hosting=cloud&tab=overview
Regards
Dave
Markus
Thanks we will check it out.
