Sub-epics
Jethro Waanders February 13, 2025 edited
I like to add sub-epics, so the parent of an epic is another epic. Can't find it in the documentation. Is it possible?
6 votes
Walter Buggenhout
February 13, 2025
Hi @Jethro Waanders
No, that is not possible. Epics have their own hierarchy level - at best, you can link them, but the relationship is not hierarchical then.
Hope this clarifies!
Thanks a lot.
Hannes Obweger - JXL for Jira
Hi @Jethro Waanders,
as already suggested, sub-epics aren't really supported in Jira's built-in issue hierarchy.
This being said, since issue links can be established between any pair of issues, you can also establish them between two or more epics. E.g., you could create a new issue link type is parent of / is child of, or something of the like.
The downside is that Jira doesn't "recognise" issue links as parent/child relationships, and won't give you any relevant features. However, if you're open to solutions from the Atlassian Marketplace, you'll find a number of apps available that can help here.
E.g., issue-link-based hierarchies are supported in the app that my team and I are working on, JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a number of advanced features, including support for configurable issue hierarchies. These issue hierarchies can be based on Jira's built-in parent/child relationships (like Epic/Story), and/or based on issue links of configurable issue link types.
This is how it looks in action:
In the above hierarchy, "sub-epics" WORK-148 and WORK-146 are connected to their "parent-epic" WORK-431 via issue links.
Issue hierarchies can also be combined with JXL's other advanced features, such as issue grouping by any issue field(s), sum-ups, or conditional formatting.
Best,
Hannes
Rahul_RVS
Hi @Jethro Waanders
You can use Issue links to create an epic a child of another one. However Jira natively does not support this and you will have to rely on a mktplace app to view this hierarchy. If you are open to try out one, do take a look at
Issue Hierarchy
The app allows you to create a hierarchy based on standard jira structure (Epic -> Story/Task -> Subtask) or even with your issue links. You can view %complete progress at each parent level. The app has multiple features as below :
- Sum up values to see overall progress for your Issue Hierarchy
- View the full hierarchy of linked issues, Portfolio/Advanced Roadmaps, Epics, and Subtasks
- Apply filters to put the focus on the relevant data only
- Excel like editing for all the values right on the report and see real time progress updates
- Export to a CSV file
- Embedded Epic Hierarchy on Issue Screen
- Dashboard Gadgets
(Disclaimer: I work for RVS, the vendor for this app)
Register Now
