Sign up Log in
Subtassks creation
Manar El Kefi August 21, 2024
Hello , I want to restrict subtasks creation per issue type and when parent status is Done using forge and using the trigger avi:jira:created:issue .The restriction when parent is done works but restriction per issue type doesn't work showing these logs : Parent issue key not found. Retrying... . Here is the function :
export async function restrictSubtasksFunction(event) {
  const { issue } = event;
  let issueDeleted = false;
  async function getParentIssueData(issue) {
    const parentIssueKey = issue?.fields?.parent?.key;
    if (!parentIssueKey) {
      console.log('Parent issue key not found. Retrying...');
      return null;
    try {
      const response = await api.asApp().requestJira(route`/rest/api/3/issue/${parentIssueKey}`);
      if (!response.ok) {
        const errorMessage = await response.text();
        console.error('Erreur lors de la récupération des détails du parent :', errorMessage);
        return null;
      return await response.json();
    } catch (error) {
      console.error(`Failed to retrieve parent issue data: ${error.message}`);
      return null;
  if (issue?.fields?.issuetype?.subtask) {
    try {
      let parentData = await getParentIssueData(issue);
      // Retry if parentData is null
      if (!parentData) {
        await new Promise(resolve => setTimeout(resolve, 3000)); // Attendre 3 secondes
      if (parentData) {
        const parentStatus = parentData?.fields?.status?.name;
        const parentIssueType = parentData?.fields?.issuetype?.name;
        // Vérification du statut du parent
        if (parentStatus === "Done") {
          issueDeleted = true;
          await api.store.set(`popup-${issue.key}`, {
            show: true,
            message: 'Sous-tâche supprimée car le parent est en statut "Done".',
          return {
            statusCode: 400,
            body: `Impossible de créer une sous-tâche car le parent est en statut "Done".`,
        // Vérification du type de l'issue parent
        if (parentIssueType === "Task") {
            show: true,
            message: 'Sous-tâche supprimée car le parent est de type "Task".',
          return {
            statusCode: 400,
            body: `Impossible de créer une sous-tâche car le parent est de type "Task".`,
      } else {
        console.log('Parent issue details could not be retrieved after retrying.');
    } catch (error) {
      console.error(`Erreur dans consolidatedRestrictionFunction: ${error}`);
      return {
        statusCode: 500,
        body: `Une erreur s'est produite lors de la vérification du parent : ${error.message}`,
  return {
    statusCode: issueDeleted ? 200 : 500,
    body: issueDeleted ? 'Subtask is deleted because of parent status or type' : 'Subtasks allowed.',
Ryan Brailey
August 26, 2024
For Forge-related questions, you may like to post here instead: https://community.developer.atlassian.com/
Upcoming Jira Events
