Suddenly all boards missing from JIRA
Rakesh N January 7, 2019
When I click on Boards & then view all Boards, not a single board name is coming in list.
I also tried seeing in all existing projects & not a single project has any board.
It was there till 2,3 days before.
Not sure what happened then.
Can you help us to bring back all boards?
Thank You.
Olga Videc
Hello @Rakesh N
My guess is that someone changed sharing settings on the board or removed you from the group with which the board is shared.
Do this go to  cog - > system -> Audit log
And there you will see the log who changed what and when.
Hope it helps.
BR, Olga
I tried checking logs but that did not giving any information about role change.
User is not able to see board, also I checked using admin login & not able to see board for any project.
Is there any option to check when it got removed?
Something from Database?
Olga Videc
Nothing here is indicating that.
You used a filter for this board or it's based on a project.
Have you removed any filters recently? Or changed project names?
Rakesh N January 9, 2019
No project name changed.
Could not figure out.
As user was agree to do some rework, Restored JIRA instance with backdated backup.
All set now.
Thank you.
Olga Videc
Glad you fixed it :)
Register today
