Sum Two Number Fields via PF / Scripted field
Hardik Parekh
I want to display sum of two number fields to third number field.
Number Field 3 = Number Field 1 + Number Field 2.
Can you please suggest how to get this via Workflow PF / using Scripted field ?
I went through many answers in community but I didn't find confirm answer anywhere.
Pete Singleton
December 3, 2019
You need to created a custom field using a plugin (Jira Misc Custom Fields., or ScriptRunner).
You can then define the Groovy script in the scripted custom field to extract and sum the two other fields.  You will need the IDs of the two custom fields to be summed, the example script below adds two custom fields with IDs 1234 and 4321:
fieldA = issue.get(customfield_1234)
fieldB = issue.get(customfield_4321)
return fieldA + fieldB
 You can add extra code to check for null values when extracting the field value, e.g.
fieldA= issue.get(customfield_1234) != null ? issue.get(customfield_1234) : 0
Leena Swar November 12, 2020
Hi Pete,
I am getting some declaration errors using the code. Can you please ping me the exact code for subtraction.
Regards
Viswa Mohana Reddy
