Dear Community!
How can I summarize the story points of an epic in a JQL?
BR Markus
hi there,
you can't sum up story points in the issue navigator. However you have two options:
1. scripted field with Scriptrunner
https://scriptrunner.adaptavist.com/5.0.4/jira/scripted-fields.html
2. Export issues from the issue navigator (CSV) and use Excel to sum certain number field.
I hope this helps somewhat.
Krisz
Hi Krizsz,
Many thx. I try to use option 1.
Thx Markus
