Summarize efforts from stories/tasks to epics
Hans-Hermann Hunfeld
Reading the actual problems about using epics and being restricted to a 2-level-hierarchy we re going to use epics only as a collections of stories and tasks very similar to another kind of meta tags (-> labels). Now we should be able to identify the high level tasks on the "big picture" of our to be developed application. This about 20 epics will be related to about 100 stories which are the highest hierarchy level in GH sprints.
As we re now going to evaluate effort on the epic level i would like to notice them in each epic issue, but for my understanding there will be no summarize function like JIRA provides on a story/task <-> subtask, isn t it? So i would have to update the spent effort time by time manually? In fact because of the missing link nobody really will work on them, so it s only a workaround but no solution!
Additionaly i put all these epics to an individual version (without any parent) in order not to mix up any efforts, is this a possible option?
In a perfect world there would be following structure:
Epics <-> Stories <-> Tasks <-> Sub-Tasks 1.level <-> Sub-Tasks 2.level <-> Sub-Tasks n.level
All efforts are summarized to the (single) parent issue, all other relations via issue linking is just informational. If no estimated effort is entered on the parent just calculate them from the childs, otherwise take the manual entered one, effort spent should be summed up. This would ease up the initial effort estimation (can be done on epics -> top-down) and will be improved while working on the stuff itself (bottom-up).
At the moment i cannot understand why this should be as complexe, so please hurry up to enable all JIRA customers to work like this, thanks!
Pushpkant September 23, 2012
When I link story with Epic then is it possible that Story Points of "story" issue type get aggregated with Story Points of "Epic " issue type?
Renjith Pillai
April 23, 2012
Not really, technical tasks do not have story points. It is only effort estimates and effort estimates of technical tasks are summed up to the story as well.
Hi Renjith,
the story points at story level is quite good to have a rough (top down) estimation, we re also using them as it s a core method of Scrum. But in my opinion also the efforts are important, we use them during a sprint as a bottom up cross check. Our developers enter the estimation latest while starting progress on a single effort in order to enable the project manager to see what s going on.
By the way, it sounds like story points are summarized from task to a story, aren t they?
Renjith Pillai
April 23, 2012
Hans, just a comment.
Epics indeed have a high level aggregation called Themes, but this again is just a label. There is no effort aggregation there. And at story level, there is actually no effort estimate available, it is in story points (which is NOT efforts).
