I have Jira OnDemand. I use search a lot but for finding the summary. For example i have issue "ev-NX30ZZ"
When is search for "ev-nx30" or "nx30" the issue is not found.
Is it possible to search in the Summary ONLY and use wildcards? I want this set as the default search function.
thnx!
Hi Maarten,
you can use the following JQL to search on the summary using wildcards :
summary ~ "%nx30%"
I don't think you can set the default search function.
Best regards,
Peter
BTW : men beste wensen voor 2014 :)
Hi, yeah, I tried doing that but it seems like wildcards are not working. I can do this with the Basic Searcher and than add the Field 'Summary' and type "%nx30%" but it does not work. When I type the entire value, the issue is found.
Even in Advanced Mocde and typing the the string you posted it gives nothing. Is it possible Wildcards are turned off?
BTW: Jij ook een goed jaar!
Nope, nothing. I get an error with your last suggestion. * is not allowed as first char for searches. Searching "%nx30*" also gives nothing. Is % a supoprted wildcard?
After some more research : no % isn't a supported wildcard, my mistake.
It seems to be a known issue that you can't start a text search with a wildcard, look here for the issue : https://jira.atlassian.com/browse/JRA-6218
Could you try the following in advanced search : summary ~ "nx30*"
It's wierd that my local instance didn't give an error messages on the wildcards.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
