When using Jira integration with Swarm, we can put a Jira link into the check-in description, which throws a link to the CL in Swarm on the Jira itself. However, this only seems to show up in old issue view.
Is this a feature not yet supported by new issue view?
Sample issue in new view:
Same issue in old view, if you see the links to section.
(Pardon the purple.)
Hi @[deleted]
Is it possible to post a screenshot of the relevant section from the old issue view? So we can get a better picture of what is missing in the new issue view
Yes, I posted a snippet of the same issue in both views.
Edit for more context - As you can see, the 'links' section appears just fine in both views, but for some reason, it looks like the swarm links are their own link type that I can't edit.
@[deleted]
Based on this screenshot, it looks like the Swarm plugin needs to be updated to support the new issue view.
Okay, we'll give that a shot.
Register now
