Hi
Does anyone use their Swimlane column to set priority?
Top on the Swimlane is the first you should be working one.
The bottom on the Swimlane is lowest priority.
I hunted for info but could not find anything.
Got a link that talks about properly using Swimlane items (task/story/bug)?
Steph
@Stephanie Beach, while I do not use this way I do know others that have. It is easy to configure for sure. Generally, I will only callout the "Highest" priority and call the Expedite. Often this is there by default when you create a board.
To do what you are asking...
You are most welcome Stephanie. If your question is now resolved be sure to click the checkmark above to accept solution as it helps others when they have a similar question.
