Our burndown chart shows only hours estimated and spent, which is great but I would like to see the story points, too. I just cannot figure out how to switch it.
An additional question: is it correct that I cannot see the number of story points when I open an issue? I only see the number of SP in the planning board (in the small icon) or in the detail tab. And I assume it is correct that I cannot change SPs once the story is in a sprint.
Community moderators have prevented the ability to post new answers.
Hi Petr,
The burndown chart uses the Estimation Statistic set for your board, which in this case, it seems to be the Original Estimate field. Please edit the Estimation Statistic of your board to display Story Points and you should be all set.
As for your additional question, it seems the Story Points field is not present in the screen used to create issues. Please see Configuring Screens for more details about this.
Hope this helps.
Clarissa.
Actually the Estimation statistic is set to Story points. As for the appearance, I cannot see them in the Issue navigator either, only in the planning board,
While I am an administrator for the board I am working with, I am not able to change the estimation statistics fields (either time tracking, or estimation statistics), those fields are both grayed out for me. Is there something I'd need to do prior to attempting to make that change?
