Sign up Log in
Table Wiki Renderer Not Working
Donna Benton
I am using automation to add text and a table to the description field with every new ticket created. I used this link to format my table: https://jira.atlassian.com/secure/WikiRendererHelpAction.jspa?section=tables
However, when I run this rule, the table does not render. I am seeing the bar's (pipes) with the words only.
Automation Text:
||PN OR VPN||DESC||
|col A1|col A2|col A3|
After Running Rule:
Tuncay Senturk
May 14, 2024
Hi @Donna Benton
Make sure there are no spaces at the start or end of your table separators (|| or |). Also, verify that each row has the same number of separators. In your example, you have two columns in the header row but three columns in the data row. This mismatch can cause the table not to render correctly.
I hope it helps!
Donna Benton
@Tuncay Senturk
I will give this a try. Thank you.
Donna Benton
@Tuncay Senturk I gave that a try and it still did not work.
Matt Benschop
September 12, 2024
The plot thickens. When I use the CTA Create button, it doesn't work (you just see the pipes etc). But if I click the plus icon on the back log section, it does work (you see the table layout).
atlassian, ace, atlassian community event, donation, girls who code, women in tech, malala fund, plan international, kudos, community badge, badge, atlassian badge, International Women’s month, International Women’s Day, women's month, women's day
10 for Change at Atlassian Community Events
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
Upcoming Jira Events
