Tagging tickets automatically when moved to done
Sherry Nightingale
Hi
I would like to tag tickets automatically when moved to done with 'unvalidated' this is every ticket within one project
I would then like to be able to change 'unvalidated' to 'validated' on a selection of tickets that I spot check - I would like to make this change via a button or some simple way that doesn't open it up to human error
Sherry
Pavol Gočal
May 14, 2024
Hello @Sherry Nightingale
you can use labels to tag tickets with automation rule or using post-function on the transition to "Done" status.
To change the tag, you can create simple transition on status "Done" and in post-function, you can delete the label "unvalidated" and then add "validated". When the transition is created, you will also have a button available in the issue detail.
Vicente Domínguez _Decadis AG_
May 14, 2024
Hi @Sherry Nightingale and @Pavol Gočal,
I am part of the Decadis team and it would be possible to add a specific label in the transition to the Done status with the post function Update fields of our app JWT for Jira Cloud.
If there are some issues that are transitioned but should not be updated, an expression could be added to the Conditional execution section of the post function to restrict its execution.
If you are interested in our app and need more information about how to configure the post function for this purpose, please, feel free to create a request in our support portal or to reply to us in this thread.
Best regards,
Vicente
Sherry Nightingale
Thank you @Pavol Gočal and @Vicente Domínguez _Decadis AG_
I went with the automation rule option and this seems to be working fine
