I'm having trouble viewing my tasks on the board, because now the tasks appear as a table, making it difficult to access them.
This happened after I upgraded my Jira plan to Standard.
I need to return this view to how it was before, because it made it much easier to access tasks and subtasks.
I've attached an image of how my tasks are now displayed.
I would really appreciate if anyone could help me.
Estou com dificuldade em visualizar minhas tarefas pelo quadro, pois agora as tarefas aparecem como uma tabela, dificultando o acesso das tarefas.
Isso ocorreu depois que eu melhorei o plano do Jira para Standard.
Preciso que essa visualização volte para o que era antes, pois facilitava muito o acesso das tarefas e subtarefas.
Em anexo segue a imagem de como encontra-se agora a visualização das minhas tarefas.
Agradeço muito quem puder me ajudar.
Hi @Luis Felipe Tomazela , this is an ongoing feature experiment where the Child Issues and Subtasks on Issue View are being made configurable by bringing the issue table into Issue View, it's part of improvements addressed in this feature request: https://jira.atlassian.com/browse/JRACLOUD-70206, if you want to disable this experiment you can raise a support ticket.
How do I open a support ticket, to disable this viewing mode?
you can raise one here to request this.
