Do you mean for:
#1 is probably more difficult to solve as the comment text could always change
#2 can be checked using a rule with a scheduled trigger and a condition on {{issue.comments.created.max}} for the last date added...assuming the comments list is not always returned in the order of creation (due to possible updates). If there are updates, the updated attribute can also be checked.
#3 can be done using a combination of smart value, list filtering and finding the maximum date, and then using that in a condition.
you would need to create a custom date field for 'last comment' then use in Automation to compare to your 7d threshold. Personally I don't like this. Maybe you could consider last updated date?
