I'm trying to create a saved filter for use with a Team Board; I cannot seem to figure out how to form the JQL correctly such that the Team Board where I'm using the filter doesn't consider the filter to be a "complex filter".
In words, I'm trying to retrieve:
I've tried everything I can think of, lastly being making each of the above a separate filter, then grouping them all together for the Board's Saved Filter; still doesn't work.
#1 Saved the following JQL with Name= Epics
project = ABCD AND "Field Name" = Customer ORDER BY Rank
#2 Saved the following JQL with Name= Backlog Items
issueFunction in issuesinEpics("filter = Epics") ORDER BY Rank
#3 Saved the following JQL with Name= Subtasks
issueFunction in subtasksOf("filter = BacklogItems") ORDER BY Rank
I think created one last filter which calls all 3 filters above:
filter = x OR filter = y OR filter = z ORDER BY Rank
I still get the complex filter notation on the associated Board which means the Create Sprint and Complete Sprint buttons are greyed out. I'm no JQL expert and am at my wits end!!!!
thank you in advance for any help!!!
Hello @Kelley Cooper
The issue is Query #2. It is not constrained to specific projects. You will need to update that one to include "project=ABCD" as part of its criteria.
Epics can have child issues in other projects so without that constraint Jira is interpreting #2 to mean the child issues could be in any project on your Jira system.
You will need to do the same with Query #3.
Thank you so much for your response, @Trudy Claspill !! I tried so many different variations I couldn't "see the forest for the trees" ;)
I settled on the following; the filter is no longer being interpreted as complex, so the Create Sprint and Complete Sprint buttons are no longer greyed out for those associated with the Manage Sprints permission...hooray!!!
project = ABCD AND issueFunction in issuesinEpics("filter = Epics") ORDER BY Rank
project = ABCD AND issueFunction in subtasksOf("filter = BacklogItems") ORDER BY Rank
Show up and give back by attending an Atlassian Community Event: we’ll donate $10 for every event attendee in March!
Join an Atlassian Community Event!
