Team Trax - Pending Request
Alejandra Martin
Hi everyone. I'm testing free trial of Team Trax. When i entry a eventy like vacations, date are showed correctly in calendar, but in approveer screen pending request shows one day before of dates selected.
Is someone experimented this problem?
Regards
Alejandra
Alejandra Martin
Hi. Thanks for your response, clearly not. Users and approvers are in Uruguay (GMT-3), cloud instance is in USA?
Brant Schroeder
@Alejandra Martin does the cloud instance timezone match the approvers timezone?
Brant Schroeder
That is the issue.  You need to align them.
(1) Default Instance Timezone
To check/change the default timezone in your Jira instance, you'll need to be a Jira Admin and then...
  1. Go to Settings (cog icon in top-right corner) > System
  2. Choose General Configuration from the left-hand menu
  3. Press the Edit Settings button in the top-right corner
  4. Ensure the Default Time Zone is set correctly - if not, change it and update it
Just remember that if you have users globally, this is the default time zone - so choose a timezone which the majority of users operate in!
(2) Personal Settings
To change your personal timezone settings...
  1. Go to Settings (cog icon in top-right corner) > Atlassian Account Settings
  2. Select Account Preferences from the left-hand menu
  3. Check your Time Zone - if it's incorrect, change it
