Team assignment field in stories is blank
Kheireddine ALLAL
October 29, 2024
Dear Atlassian community, we are no longer able to assign a team in stories :
When the "Team" field is expanded, it is empty whereas we are supposed to see a group of teams.
Did you experienced this kind of issue ?
If yes, if you could kindly share in this topic how this issue was solved, I'd be more than grateful.
Thanks !
K.
2 accepted
Prachi Bolar
October 29, 2024
Hi @Kheireddine ALLAL ,
Welcome to the community :)
There is an ongoing incident on the Atlassian end that has affected the team field for a few customers,
The field is not selectable, the values are not there etc.
Please raise a ticket to support here: https://support.atlassian.com/contact/ and the support will update you when the issue is resolved.
Thank You,
Prachi
Marc - Devoteam
October 29, 2024
HI @Kheireddine ALLAL
Welcome to the community.
Do you teams still exist, under the teams option or in Jira Plans?
Marc - Devoteam
October 29, 2024
Relating to the answer from @Prachi Bolar
I can concur there is an active incident on the Team option, see https://jira-software.status.atlassian.com/
Prachi Bolar
October 29, 2024
Yes thats correct @Marc - Devoteam  The team updated this a few minutes back
Like • Marc - Devoteam likes this
Kheireddine ALLAL
October 29, 2024
Dear Marc,
Thanks for your quick answer.
The problem is solved now, looks like it was general.
Thank you
