Team field validator (script runner)
Sebastian Krzewiński
Hi all!
I'm having an issue with creating validator for Jira's Team field (team picker). I used
issue.customfield_30101 != null
but if field is empty or not validator don't let me further.
Can you help me with this?
Seba
2 accepted
Maciej Dudziak _Forgappify_
October 30, 2024
Hi @Sebastian Krzewiński
Team field is visible in Jira expressions except for Create issue transition. I remember testing it. There is also an open bug for the Create transition: https://ecosystem.atlassian.net/browse/ACJIRA-2504
Cheers
Hi @Maciej Dudziak _Forgappify_
Thanks for info. I will be watching this ticket.
Kristian Walker _Adaptavist_
October 30, 2024 edited
Hi Sebastian,
Looking at the docs here it appears the Teams field is a special field that Atlassian provides which should have the ID customfield_1001 in all instances as it is a locked System field.
The page mentions the field can be accessed via the Rest API but does not mention it can be used in Jira Expressions or in the Jira Expressions Framework documentation.
Due to this, I believe this field is not supported and cannot be validated with Jira Expressions.
I hope this helps.
Kristian
Hi @Kristian Walker _Adaptavist_ !
Thanks for your reply! I'm also afraid that for now this field is unsupported :/
Seba
