A year ago, we checked into team reporting and we couldn't run the time tracking report. I was wondering if it is now an option?
Is there a list of reports that can vs. can't be run in a team setup now that a year has passed?
Thanks in Advance,
Randy Hoffman
Team-managed Jira Software projects contain the following reports:
The burnup report tracks how your team did when comparing the work completed in a sprint with the work you planned to complete. It requires the Sprints feature to be enabled. Learn more about the burn up report.
The cumulative flow diagram helps you identify bottlenecks in your project’s work by showing how long issues stayed in each of your statuses. Learn more about the cumulative flow diagram.
The velocity report breaks down how much work your team was able to complete over a period of time to help you plan your next sprint. It requires the Sprints feature to be enabled. Learn more about the velocity report.
The sprint burndown chart shows how much work has been completed in a sprint against what’s remaining. It can help you predict and avoid scope creep. It requires the Sprints feature to be enabled. Learn more about the sprint burndown chart.
Learn more about reports in team-managed projects.
(pulled this out of the Team Managed Project Report Setting Help Window)
You can check out the eazyBI app for more custom reports. You can check our demo account for many report examples. Any report can be used for next-gen projects as well.
Daina / support@eazybi.com
