We are using the TeamCity Jira integration to send build status information from TeamCity to Jira. This has worked fine for about a year now, but 2 days this stopped working. TeamCity logs show that Jira returns a 401 Unauthorized error when sending the build status.
We are using OAuth credentials to communicate to Jira, and have already checked the credentials. We even generated new credentials and used those but they also don't work.
If I try to use the build api manually I can get an access token, but when I try to retrieve build information I also get a 401 unauthorized error.
Was something changed in Jira recently?
Same problem here. Seems quite widespread, according to Jetbrains they have received multiple reports today regarding this issue.
@Peter de BruineBy the looks of the Jetbrains issue, it's scheduled to be fixed in the next release.
@Olof Lindberg thank you for the information. I updated the integration in TeamCity and after updating it started working again!
We are also having same problem. We tried out with different tokens.
It semes like a not Jira problem.
Same problem here. Thank you for sharing the information!
Read the story
