I'm looking to install teamwork graph connectors. I follow the steps as explained in
https://support.atlassian.com/organization-administration/docs/manage-teamwork-graph-connectors/
Go to http://admin.atlassian.com/.
From the top menu, select Apps.
Under Sites, select your site.
From the side menu, select Connected apps.
Select the button Explore apps, then Add Teamwork Graph connector.
Follow the instructions.
I got stuck on step 5. I can't seem to find a 'Teamwork Graph connector'
Can someone point me in the right direction?
Hey Francis
Hope you're doing well!
Here is what I have in my instance:
Under Product > Select site > Connected Apps > arrow near Explore Apps I can see add teamwork graph.
It points me out to a list of Connectors.
Hope it helps!
