×My company has multiple company managed projects. We recently have been trying to become aligned on ticket management and one of the ways we aim to do so is to create templates for tickets. Is there any way to make templated tickets in company managed projects as you can do in team-managed projects?
Please let me know if it is, or if there are any work arounds to solve this issue.
Hello @LJ Durante
If you're seeking for an easy way to do project templating, you can try our app Elements Copy & Sync that allows you to clone and sync a full hierarchy of issues with all their content (summary, description, custom fields, comments, attachments, etc).
You can check our guide here.
The app is for free during 30 days (and it stays free under 10 users).
Clara
Hi @LJ Durante
It's not possible using native functionalities in Jira. The only way is using app for that. I can recommend a solution developed by my team: Issue Templates Agent for Jira. This app works on the native Create issue screen. You need to only create templates for issues by defining values in fields. We support not only Summary and Description but also a long list of system and custom fields.
With our app, you can also create a template for the whole structure (Epic > Story Subtasks).
I would be happy to show what you can achieve with our app during the free call which you can book under this link: calendly.com/appsvio 🙂
Kate
Hey @LJ Durante ,
Welcome to the community!
There are indeed a few template apps available on the Atlassian Marketptlace. We recommend trying our Easy Issue Templates for Jira app for Free!
You can easily save your Jira ticket as a template and use it for the recurrent creation of new Jira tickets across your company (or team)-managed projects
You may also utilize Variables functionality and multilevel hierarchy structure of Epics, Tasks, and Subtasks to boost your team's performance and standardize the process of Jira issues creation.
Feel free to get in touch!
Pavel
Hey @LJ Durante I am the Product Marketing Manager at Seibert Media, and I think our Templating.app could be a good solution for you.
With our features, administrators can create Jira Project Templates with pre-defined schemes. After setup, non-admins can create projects based on templates with available schemes.
You can also create templates for issues and issue hierarchies (epic, task, subtask) and add various information like descriptions, due dates, and assignees. You can also add pre-existing issues to your template.
Hope that helps! If you have any further questions about your use case, feel free to jump on a call with us.
Welcome @LJ Durante ,
When you say "templates", are you referring to defining a set of required fields, a required format for your issue descriptions, or something else?
Fields can be controlled via Screens and workflows, but the other options are not possible out of the box.
a set of of required fields. For example we have the description text bot, then I would like to add potentially a DOD text box and maybe something else. But from what it looks like, it is not a something that is currently available?
@LJ Durante To mark new required fields, like summary and description, you need to edit the "field configuration" being used by the relevant issue type in your project(s).
I typically create a copy of the current field configuration, edit the fields in the new copy to mark the necessary fields as "required," and then associate that field configuration with the issue type you want to template.
What I've done for a recent use-case was:
Once you have what you like, you can add the new issue type, screen scheme, and field configuration to the current schemes that are shared by the company-managed projects to quickly apply shared settings across all projects.
Reminder- if you change the "default field configuration" and start making fields "required," it'll impact all projects and all issue types which can cause a headache. For example, if "DoD text box" is marked required, it'll have to be filled out for any non-DoD related issues unless set-up properly. Which is why I choose to apply a "field configuration" to a specific issue type.
@LJ Durante Welcome! You might take a look at this thread: https://community.atlassian.com/t5/Jira-questions/What-s-the-best-way-to-create-a-JIRA-Issue-template/qaq-p/753497
Nicolas
Cloning a single issue seems like overkill. I'd be more likely to recommend copying a description from a Confluence page instead of this.
Learn more
