After Greenhopper upgrade to 6.0.1 and other plugins, I see the message The JIRA server could not be contacted. This may be a temporary glitch or the server may be down.
I use JIRA 5.0.2 on Linux (Suse).
How can I fix it?
It will fix after restarting JIRA
above page is the solution. I will do that and then write result
Did what was noted in link and was successful in getting the issue resolved.
Thank you for sharing Jaejoon
It might be because of workflow... Mine was resolved by removing the screen which was used when issue was moved to DONE in a workflow..
