Sign up Log in
The UX for selecting tickets in the backlog is awful
Alan Ferneyhough June 5, 2024
Not really used to complaining, I have been using JIRA for 8+ years and in general find it to be a great system for agile development teams... and I am probably screaming into the void here, but the "new" (ok it's been like this for a while) way to select multiple tickets in JIRA Backlog is BAD.
It's actually REALLY BAD.
So I've just been planning a sprint and wanted to move some tickets out of one sprint and into another.  Should be simple, right? Select my tickets and use the wonderful "Move to" option.
NO!
I've selected the tickets and then - fortunately for me - remembered that JIRA is now retaining the selection of the last ticket I viewed.
So I have to search through all of my sprints and my backlog to find any tickets that have previously been selected, and de-select them one at a time so that I don't, for example, MOVE A BUNCH OF TICKETS OUT OF THE CURRENT SPRINT BY ACCIDENT (I've done this a few times and sometimes only realised weeks later when a planned piece of work did not get done in time).
Frankly this UX is rubbish and I can't believe there isn't a workaround.
Am I the only person suffering from this? Is there something I can do to make this work better for me?
Thanks, in anticipation and apols for the CAPS :)
Mikel Garcia Bartolome
June 7, 2024
I understand your frustration! Selecting multiple tickets in the backlog for bulk actions can definitely be cumbersome. While there isn't a perfect solution yet, here are a few options that might help:
  • Shift-Click: You can try using the Shift-Click method to select multiple contiguous tickets in the backlog. Hold down the Shift key while clicking on the first and last ticket you want to select. This should grab all the tickets in between.
  • JQL and Bulk Move: If you're comfortable with JQL (Jira Query Language), you can create a JQL filter that selects the specific tickets you want to move. Then, you can use the bulk move option available in the search results to move them all at once.
  • Keyboard Shortcuts: Jira offers some keyboard shortcuts for navigating and selecting issues. You can explore these shortcuts (accessible through the "?" icon in the top right corner) and see if they help with faster selection.
While these aren't ideal replacements for the previous multi-select functionality, they might offer some relief. Hopefully, future updates from Jira will bring back a more intuitive way to select multiple tickets in the backlog.
In the meantime, feel free to share your experience and these workarounds with others in the forum who might be facing the same issue. You're definitely not alone!
