The timetracking plugin
aynura.nasibova
September 14, 2021
Hello!
We are using the Jira for Server. We have a need for a plugin (time tracker) that synchronizes with the Active Directory Attributes Sync plugin.
We would be grateful if you could suggest a plugin based on our needs:
We need the report to display full information about the user (name, title and department)
If the 1st point is not possible, then there was a synchronization with the plugin Active Directory Attributes Sync.
I`ll be very thankful if you could help!
Gloria Ojukwu
@aynura.nasibova try time reports as it works for me, https://marketplace.atlassian.com/apps/1212077/time-reports?hosting=cloud&tab=overview. for the department, you can also create issue types that represent those, for example, QA, Frontend, etc. let me know if this works.
