Ticket Moving only when Due Date is updated
Abhishek Sisodia May 31, 2024
Hi Users,
I want to setup a validation on tickets that only if the Due date is updated, then ticket can be moved to another status.
Kindly help out how to set this up.
Valerie Knapp
May 31, 2024
Hi @Abhishek Sisodia , welcome to the Atlassian Community and thanks for your question!
You should be able to achieve this with a validator and a transition screen with the Due Date on it.
Please check out the documentation here: https://support.atlassian.com/jira-cloud-administration/docs/configure-advanced-issue-workflows/
I hope this helps.
Cheers
Marc Jason Mutuc
May 31, 2024
You can use validators on your workflow.
