Using Confluence, we have listed issues in a table and we having an issue with the "Time Spent" column.
On JIRA, the field displays correctly in terms of days and hours but on Confluence, that time is translated to seconds.
How do we configure Confluence to show days as well?
Thanks.
IMO you need to ask Atlassian support about that. As I understand you display values from jira by using default Jira issues macro.
Seba
I am having this same issue @Drishti Maharaj
I am posting a Jira Issue filters into Confluence and it auto populates the tables nicely (new format recently) and with this it is displaying the Time Spent in seconds. This has only just started to display in Jira like this, as it used to display perfectly as Jira did, which was in the correct times, hours, minutes etc.
Very unhelpful.
Any solutions to this?
Thank you
HI,
Using Jira legacy from the insert dropdown on the Confluence page helped fix this. This is a workaround for now.
