Time Spent Field Not Showing Up in Transition Screen
srainsba@ruan.com
I created a transition screen so that when issues are transitioned in our workflow, people can add time spent.  However, the time spent field is not showing up.  First screen shot is what I need.  Second screen shot shows what comes up in the transition.  Third screen shot is how the screen is configured.  Any insight on this would be greatly appreciated.
Duc Thang TRAN
June 28, 2024
Hello  srainsba@ruan.com
I believe your configuration is correct. It might be worth checking if your screen has been added to the transition.
If all verifications are done, I hope someone else can identify the misconfiguration.
srainsba@ruan.com
Thank you so much for the quick response.  The screen has been added to the transition.
I even tried to do a validation on it based on what I read in other posts and still not seeing it.
If I should put in a support ticket, please let me know.  Thanks.
Let's build A Rovo Agent 🤖
Save your spot
