Time Spent by resources
Radhika Gupta January 3, 2022
Hi Everyone,
I was trying to generate a report or a dashboard view that provides me with the
1. Time spent by a resource across different projects, epics or tasks
2. Total Time spent by all the resources on a single project (for a given time range or monthly)
Is there a way we can achieve this by using the standard widgets provided by JIRA or any recommendations on any add ons that could provide all the time tracking metrics
Kindly Advise
Radhika
Ewa Grabowska-Ptak_SolDevelo_
Hello @Radhika Gupta ,
If you are already using Jira Time Logs, I would recommend you our app - Worklogs Time Tracking and Reports. It allows you to create a custom reports from your Jira issue Time Logs. So, you can check how much time has been logged to a specific project, component or any other custom fields.
Hope it helps! In case of any questions, please feel free to contact me here, I'll be happy to assist you.
Radhika Gupta January 12, 2022
Thank you so much.  I started exploring the features and I was wondering if there was an option to generate a pie chart of the timesheet or reports we generate out of work logs.
Kindly advise
Radhika
Tahir Mehmood February 16, 2022
This one is very useful. But I need to present management though dashboard. Please guide how to get it while using Rich filter query.
5 votes
Mariana_Pryshliak_Saasjet
 If you're ok with the third-party add-ons, I recommend you to try Time in Status for Jira Cloud, which allows getting the data you need:
- Time spent by each assignee across different projects, epics, or tasks;
- Total Time spent by all assignees on a single project (for a chosen time range or monthly);
- Issue Age data
And much more by generating 7 types of status time reports.
It allows getting all the data on the grid, and Pie or Bar chart view. And you can export data as CSV or XLSX files for further analysis.
This add-on is developed by my SaaSJet team and is free for using up to 10 users. If you have any questions, feel free to contact me.
Nataliya Vasyliv_Reliex_
Hi @Radhika Gupta
I'm Nataliya from ActivityTimeline team. If you will consider an add-on ActivityTimeline could fits your request. ActivityTimeline provide a resource planning and availability on a timeline dashboard.
ActivityTimeline allows to understand how much time users spent on a specific issue or project with workload indicator on timeline view dashboard.
Project Planning for Jira.pngYou can generate a report to track time spent by all the resources on a different projects for a selected period.
Hope it helps.
Best, Nataliya
Rahul_RVS
Hi @Radhika Gupta
For a readymade solution, to get the time spent data, you can try out our plugin
Agile Tools : Epic Tree, Links Tree, Time in Status & Worklogs
The app provides the following features.
Worklogs & Time tracking Report :- Track time spent by resources with multiple filters / category / grouping features. Export to csv format is also available. You can filter based on worklogs time period as well.
Along with this there are multiple other features like Time in Status, Links Hierarchy, Epic Hierarchy etc which the app provides.
