Hi!
I have a problem with the Status Time Reports by Bloompeak app, it's in the Time Status gadget with filtered results, and sometimes the gadget is implemented in the "fetching projects" status, and there is no way to select it to display the query. You have to delete and re-configure the gadget on the dashboard, and so several times a month.
Is it possible to revive a gadget without replacing it with a new one?
Thanks.
https://marketplace.atlassian.com/apps/1221826/status-time-reports?tab=overview&hosting=server
Welcome to the community !!
There are several apps with the same name in the marketplace.
Request you to please specify the vendor of the app or the mktplace link of the app.
If you are using Status Time Free or Status Time Reports app, you can contact us via support@bloompeak.io or https://bloompeak.io/support.
