Hello, we are using the time tracker support that comes by default with Jira (free plan) and I was searching for a way to get some reports on the logged time but failed to find any. I also tried Worklogs Reports, free, but it's not reporting anything although there is logged time.
Can someone please assist on how to get logged time reports please, either natively or via add-ons that actually support the native time tracker?
Thank you,
Welcome to the community!
I can recommend our Clockwork Automated Time Tracking & Timesheets Pro or Free app, which offers you the possibility to review timesheets and create reports that can be configured in various ways using break-down and filtering options, including time spent per agent. Our app supports the native Jira worklogs; it actually enhances the whole system.
Using timesheets, you can create a report and filter it based on several options including labels, or other fields. You can choose a range for a whole year and break down the data by chosen fields. This information can be also exported to Excel files.
We have recently also developed a Team feature that allows you to create Teams which can be used in timesheet filters and breakdowns. When a team is selected for a timesheet/report, all users in the team will be included in the report even if they do not have any worklogs for the selected timeframe.
Please find below the sample of how the timesheet looks like:
If you have any questions you can contact us via our help center.
Cheers!
Gracjan
I can suggest you Timeline Team Timesheets in ActivityTimeline plugin. Detailed timesheet reports are built like Lego, so you can choose various values and generate timesheet reports in a few clicks!
Here are three types of timesheet reports in the app:
1. Progress Timesheets showing the amount of logged and required work hours. It also includes non-working days and a progress bar. You can choose different timeframes and receive an understanding of the work done by users:
2. Timeline Team Timesheets are more comprehensive, as they allow to choose between different templates. Users can get a summary report, or group data by issues, project, epic and even custom fields.
3. Detailed Team Timesheets help to get more deep data on task, project, user, or epic. You can also expand this detailed report by adding custom fields from your Jira:
ActivityTimeline also offers a separate Report Module including more than 20 resource, project, team, and other reports.
Feel free to schedule free demo session or contact our support for more info:)
If you would be interested in a mktplace app to get this data, you can try the add-on we have developed. You can easily view time entries for multiple issues day wise grouped by assignees in a single view.
Worklogs Time Tracking & Timesheets
The app allows to filter/Categorize/Group By your worklogs data and a timesheet view too to track individual time spent.
Disclaimer : I work for the vendor who built this app
That is the one I mentioned I tried. We had time tracking already enabled and time logged on some tickets. I installed that add-on and went to apps to both TimeSheets and Worklog reports but they are empty
Hi Mircea,
Can you please share your contact details (email id) on support@rvsoftwares.in
We will schedule a zoom call to have a look at the issue.
Apologies for the chaser. Request you to please share details on support@rvsoftwares.in and we will setup a quick zoom call to have a look at the issue
I went with the other answer, sorry. This one doesn't look like it's doing what it should and I don't have time to chase it.
For ex, yesterday, ti wasn't showing anything in worklog reports, now it does, but the time values are incorrect (EG showing 3days when only 1 day and several hours were logged on a ticket)
Sure. No worries. Glad that you found a solution.
Just to answer for the issue, the app takes the working calendar setup in the settings screen and calculates the hours accordingly.
Thanks again.
@Mircea Craciun Can someone please assist on how to get logged time reports please, either natively or via add-ons that actually support the native time tracker?
The Analytics & Reports add-on by Screenful can provide detailed reporting of data in Jira's native time tracking. You can learn more from this blog post. It's free for up to 10 users!
While Jira's built-in time tracking feature is helpful for logging work hours, its reporting capabilities are limited, especially on the free plan. If you're looking for more comprehensive and insightful time reports, you might consider trying the Time & Cost Tracker for Jira add-on.
This add-on seamlessly integrates with Jira's native time tracker, meaning any worklogs you've already entered will be automatically included in its reports. It offers detailed Time Reports that give you insights into:
Time & Cost Tracker makes it easy to generate these reports with just a few clicks, and you can even export them for further analysis or sharing with stakeholders. It is also free for up to 10 users.
Hello @Mircea Craciun
If you use Jira's native time tracking to log time, our Worklogs - Time Tracking and Time Reports will be a perfect fit for you. It works out of the box, so all you have to do is install the app and it will display a time report like this.
You can then customize it based on your needs - change groupings, dates, filters, and many other options. Feel free to check it out - there's a 30-day free trial or book a demo with our team and we will be happy to show you the app in action and answer any of your questions.
Best regards,
Sebastian
To get detailed reports on logged time in Jira, especially if you're using the free plan, your options are somewhat limited natively, but there are several add-ons that can help. Here's a step-by-step guide and some recommendations:
Using Filters and Gadgets:
Export to Excel:
Since native reporting on the free plan is limited, add-ons are a great way to enhance your reporting capabilities. Here are a few recommendations:
Tempo Timesheets:
Worklogs - Time Tracking and Reports:
