Time Zone difference in flow JIRA
Fortune December 24, 2018
Our team is in Shanghai. I made some change and comments in Flow JIRA at 10 o'clock and I can see my previous action from the history tab of Flow JIRA. They were modified indeed at 10 o'clock. But from my colleagues' computer, it showed to me that I made the modification at 3 o'clock. I don't know why. Hope somebody of you can help me to figure out what is the root cause of this problem. Many thanks !
2 accepted
Sid
December 24, 2018
It is because your colleague is using different time zone. you can modify the timezone - Navigate to your profile right corner of the menu bar and select profile. then you will see the preferences section in the page and there is a  field for Time Zone
Sid
December 24, 2018
You can also modify the user default timezone to system default - Administration > System > General Configuration
Hi, thanks for your suggestions. We've made it already
Allert-Jan Veldman June 4, 2020
But what if the timezone for the project is wrong. We receive updates now for Jira during the day because our time-zone is wrong. Where can we change this?
Sid
June 5, 2020
Administrators can set the default timezone of JIRA by navigating to JIRA Settings > System > General Configuration > Edit Settings and change the field Default User Timezone, however, it will be applied for all users.
Like Allert-Jan Veldman likes this
