×Hi, I'm trying to find out how much time is logged (Time spent) per project per month. I can see the "Time spent" column and can sum that, but how do I know which month the "Time spent" was added?
Is there another column I can query which will let me know the date when the "Time Spent" was added?
You can do this with the help of add-ons like Tempo. There are other worklog reporting plugins as well in the Atlassian marketplace.
Hi Simon,
You can do that as well with an addon called Timescale.
There you can easily generate a monthly view/report on all the timespent per different project or set of projects.
Hope it helps.
Hi @Simon Singh ,
as @Jobin Kuruvilla [Adaptavist] said, there are many worklogs reporting plugins available on the marketplace. You can simply type 'worklogs' in the search box and give one of them a go.
All of them provide at least a free trial, so please check as many of them as you like before making a final decision.
Jakub.
Hi there! So there is NO way to do nice monthly reports out of the box, right?
I have tried with filters and gadgets and it is not very accurate unfortunately, and leaving us with excel again...
Do you have any plans on adding timesheet reports or smth like that in Cloud Jira?
Maybe app Quantify help you
Read about them on the marketplaсe, it seems to me their product should be suitable for you.
