Timeline view
Jason Chayer
Is there a way to drag and drop in the Timeline View? I have not seen an update since 2023, or at least from some of the posts I have read. Below is what I am trying to do.
It shows the Epics, I then create Stories against that Epic. Because I have multiple teams working on a story, I then create tasks and link them to the Story. I do not create subtasks against the Story because our QA team tests each task separately and then write any issues they find against those tasks.
What I am wanting to do in Timeline is have Epic shown and then the drop down have all other issues. But, I want to be able to group the tasks below the appropriate Story.
Trudy Claspill
July 26, 2024
Hello @Jason Chayer
No, that is not possible.
The Timeline view shows issues based on the parent/child Issue Type Hierarchy relationship. It can show Epics with their children nested below them. It cannot show nested issues based on generic issue links, in part because any given issue can be linked to multiple other issues and there is no inherent parent/child distinction in the generic issue links.
Jason Chayer
@Trudy Claspill  - thanks for the reply, that was my assumption.
I'm assuming you cannot drag and drop in the Timeline View?
Like John Funk likes this
Trudy Claspill
July 26, 2024
You can drag and drop both to change the parent of an issue and to change the issue's ranking compared to other issues (assuming the board's filter uses ORDER BY Rank).
Do note that only Epics and their children will display. If you have issues that do not have an Epic as their parent, then will not display in the Timeline.
Jason Chayer
Thanks @Trudy Claspill . I do see I can drag and drop on the board, but when I am in the timeline view, I am unable to drag and drop.
Trudy Claspill
July 26, 2024
What is the filter for the board?
What exactly are you trying to drag and where are you trying to drop it?
Can you use a screen recording tool, or a series of screen images, to show us what you're trying to do?
I did notice that it can be a little picky about where you "grab" the issue. If you grab it where the issue key is display, it doesn't seem possible to drag it. I made sure that I grabbed the issue by clicking in the white space to the left of the issue type icon.
Jason Chayer
@Trudy Claspill - that was it. I simply was not grabbing it in the correct spot.
Thanks for your help again.
Register Now
