You can do that easily using ScriptRunner for Jira. You can LoginManager to get this information.
ComponentAccessor.getComponent(LoginManager)
Ravi
I would love to see this script too. I'm trying to do this in both Jira and Confluence @Ravi Sagar _Sparxsys_ .
I would love to see this script as well if you could please share it that would help a lot
The following script can be run in the scriptrunner console and will output a list of users who have either:
- never logged in
- not logged on in *threshold* days (feel free to change this)
** no promises on this one, it seemed to work decently well for me*
@kdickason - for Confluence Cloud or Data Center?
I recommend starting a new question on Community (unless the question has been asked before, of course).
@Connor Bartal - thankya! Confirmed it works in Jira 9.5.0 and ScriptRunner 7.10.0. 🙌Now to get a last login date printed next to those names...
@lester Kacprzak One given by Atlassian have a join with cwd_membership will will remove non licensed users I have removed it in below query try this.
SELECT d.directory_name, u.user_name, TO_DATE('19700101','yyyymmdd') + ((attribute_value/1000)/24/60/60) as last_login_date
FROM cwd_user u
JOIN
SELECT *
FROM cwd_user_attributes ca
WHERE attribute_name = 'login.lastLoginMillis'
) a ON a.user_id = u.ID
JOIN cwd_directory d ON u.directory_id = d.ID
order by last_login_date desc
This worked. We use AD auth,
Was trying to get USER info along with AD groups associated to users. Following is my query
SELECT
u.user_name,
u.LOWER_DISPLAY_NAME,
m.LOWER_PARENT_NAME,
u.EMAIL_ADDRESS,
FROM JIRA.CWD_USER u
JOIN
SELECT *
FROM JIRA.cwd_user_attributes ca
JOIN JIRA.CWD_MEMBERSHIP m ON m.child_id = u.ID
@Connor Bartal _ worked great with additional filters and statements modified it gives the total no. of logged in users per today with threshold = 0
and this script covers lot of use cases.
SELECT
u.user_name,
u.EMAIL_ADDRESS,
JOIN
SELECT *
Hi @lester Kacprzak,
This is a free app and I have used this quite often on different occasions; Jira User Export.
Moga
Hi Iester
if you have access to the used db you can use the sql query provided at https://confluence.atlassian.com/jirakb/find-the-last-login-date-for-a-user-in-jira-server-363364638.html
All the best
Kurt
Save your spot
