I have 10-15 custom field in my project, is there any way we can trigger the listener to run only on one of the custom field on which you want?
Hello @sbhutada ,
I assume you want to trigger a listener based on the value of a custom field (on of your custom field). If so, then yes, you can do it.
This similar question might help you.
Hope this helps.
Swathi
Thanks, @[deleted] for the response.
BTW...I was looking for an approach where I only and only want to trigger the listener on that custom field rather than checking in the code whether the field is changed or not.
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
