Traceability matrix
Srecko Anzic
Which one is the best add-on for Traceability matrix in JIRA Core?
Nic Brough -Adaptavist-
December 21, 2016
Manuel
November 8, 2024 edited
Hi @Srecko Anzic
If you're using Xray for Test Management, it comes with a built-in Traceability report and that may be good enough for what you're trying to achieve.
Other test management tools have also similar reports.
Luc Filion October 4, 2019
You may also check the Impact for Jira plugin, which generate traceability reports (and not a 2D matrix with little checks per se). This can be very useful because it brings much better readability for the team members. This tool is very pragmatic. It's got an export to excel too so you can continue your flow with other tools as well.
Nick Iles _AssertThat_
Hi
We have a plugin which allows you to create, and link BDD (behaviour driven development) scenarios to user stories in Jira.  We've added a traceability matrix recently to our plugin which maps the user stories (or any issue) with the BDD scenarios.
https://marketplace.atlassian.com/apps/1219033/assertthat-bdd-test-automation-in-jira?tab=overview&hosting=cloud
If you would like a demo then please get in contact.
Nick
AssertThat Marketplace Vendor
Cheney Ma [Go2Group]
December 27, 2016
Please check if 'SynapseRT' is fit your needs.
