Traceability report in JIRA
Nikola Velevski
Is it possible to make a traceability report about released version? In my case, I have the opportunity to choose only versions that are not released.
Thanks in advance,
Nikola.
Deepanshu Natani
Checkout one of the addons in the below screenshot for traceability reports.
Martins Vanags -eazyBI-
Hi @Nikola Velevski
Please find some of the sample reports about version analysis that you could create with eazyBI very easy.
https://eazybi.com/accounts/1000/dashboards/5957-versions-overview
Feel free to reach out to support@eazybi.com if you have any question.
Best regards,
Martins / eazyBI team
Andrea July 19, 2018
Hi @Nikola Velevski
Yes, it is possible to make a traceability report about released versions. But, you would need an app to do so.
Allow me to introduce you to TraceabilityX . My company developed and mantains this app ;)
Do not hesitate in giving it a try and if you have any questions just reach our support team.
Best wishes,
Andrea
Deleted user July 17, 2018
Hi @Nikola Velevski ,
You may want to check out the add-on EasyBI, mentioned in a similar question
I have not used EasyBI for this use case though, you should be able to specify the report's criteria, for your requirements it would be released versions.
Hope this helps
