Transfer of "fixVersion" to the partner projects in Backbone Issue Sync plugin
Mario Muetze July 5, 2016
Will Backbone Issue Sync also transfer a newly created "fixVersion" to the partner projects or is this to be done by the administrator for the partner project?
Matthias Gaiser _K15t_
I know this question is fairly old, but if someone else is having this problem. The answer is simply, yes. When you setup the synchronization for a versions field, you have the option to "create missing versions".
Please make sure that the technical integration user needs the "administer projects" permission in order to do this.
Mario Muetze March 13, 2017
Thanks for your answer anyway.
Learn more
