I have the following code in which `componentList` is a list of strings
String text = "The super feature " + issue + " will be split into " + componentSize + " features, one for each component:\n"
text = text + componentList.toString() + "\n";
I am getting the following output:
The super feature SF-797 will be split into 10 features, one for each component:
[WF-ActiveTransfer ===> WILL BE GENERATED, WF-Central Security Library ===> WILL BE GENERATED, WF-Integration Server ===> WILL BE GENERATED, WF-OSGi ===> WILL BE GENERATED, WF-Service Development ===> WILL BE GENERATED, WF-webMethods.io Integration Connectors ===> WILL BE GENERATED, WF-webMethods.io MFT ===> WILL BE GENERATED, WF-WebReader ===> WILL BE GENERATED, YF-ARIS Connect ===> WILL BE GENERATED, YF-PPM ===> WILL BE GENERATED]
I would like to transform this output into the following with a new line generated between each pair of successive elements of the list:
I don't want to use a loop and keep looping as this would not be efficient.
Have you tried using:-
componentList.join('\n')
This will return all the list content as a multi-line String.
I hope this helps to answer your question. :-)
Thank you and Kind regards,
Ram
Has your question been answered?
If yes can you please accept the answer.
Ram
