×Hi Community,
I need help in reviewing and correcting my below code. I am passing the code in Conditional execution section of Transition Issues post-function (using JMWE app) in the Child Workflow.
My use-case is:
So, I want that:
Parent-Child Transition Logic:
a) When all Children of a Parent (linked via Parent Link field), transition to Prioritized, then Parent will also transition to Prioritized.
b) When some Children transition to Prioritized and other transition to either Not-Prioritized or Cancelled, then Parent should only move to Prioritized, irrespective to those Children moved to Not-Prioritized or Cancelled.
c) When all Children are transitioned to Not-Prioritized, then Parent should move to Not-Prioritized.
d) When some Children are transitioned to Not-Prioritized and other are moved to Cancelled, then Parent should only move to Not-Prioritized, irrespective to those Children moved to Cancelled. (Here, No Children have moved to Prioritized)
e) When all Children are moved to Cancelled, then Parent should move to Cancelled. (Here, No Children have moved to Prioritized and Not-Prioritized).
Problem:
Configuration:
Parent and Child Workflow are same and a Parent can transition from Approved status to either Prioritized, Not-Prioritized, or Cancelled based on transition of Children. I am using below code in Conditional Execution in Transition Issue post-function in Child Workflow from Approved status to Prioritized:
import com.atlassian.jira.bc.issue.IssueService
import com.atlassian.jira.workflow.TransitionOptions
Integer actionId = XXXX // The transition ID for Prioritized
MutableIssue parent = issue.portfolioParent as MutableIssue
IssueService issueService = ComponentAccessor.getIssueService()
ApplicationUser currentUser = ComponentAccessor.getJiraAuthenticationContext().getLoggedInUser()
TransitionOptions transitionOptions = new TransitionOptions.Builder()
.skipConditions()
.skipPermissions()
.skipValidators()
.build()
IssueService.TransitionValidationResult result = issueService.validateTransition(currentUser,
parent.getId(),
actionId,
issueService.newIssueInputParameters(),
transitionOptions)
//return true
def otherSubtasks = parent.getPortfolioChildIssues().findAll{it.issueType.id == "XXXXX" && it != issue
if (otherSubtasks.every{it.getStatus().getName() == "Prioritized"} && otherSubtasks.every{it.getStatus().getName() != "Approved"} ){
//return true
log.info("entered1")
issueService.transition(currentUser, result)
else if ( otherSubtasks.any{it.getStatus().getName() == "Prioritized"} )
{ log.info("entered2")
if(otherSubtasks.every{it.getStatus().getName() != "Approved"}){
log.info("entered3")
{ log.info("entered4")
log.info("entered5")
if(otherSubtasks.any{it.getStatus().getName() == "Cancelled"}){
log.info("entered6")}
else if(otherSubtasks.any{it.getStatus().getName() == "Not-Prioritized"}){
log.info("entered7")
else if(otherSubtasks.any{it.getStatus().getName() == "Prioritized"}){
log.info("entered8")
{ log.info("entered9")
log.info("entered10")
log.info("entered11")}
{ log.info("entered12")
log.info("entered13")
if(otherSubtasks.every{it.getStatus().getName() == "Not-Prioritized"}){
log.info("entered14")}
{ log.info("entered15")
log.info("entered16")
log.info("entered17")
log.info("entered18")
{ log.info("entered19")
log.info("entered20")
log.info("entered21")
else if ( otherSubtasks.every{it.getStatus().getName() == "Not-Prioritized"} )
log.info("entered22")
log.info("entered23")
else if ( otherSubtasks.every{it.getStatus().getName() == "Cancelled"} )
{ log.info("entered24")
log.info("entered25")
else if ( otherSubtasks.any{it.getStatus().getName() == "Cancelled"} )
{ log.info("entered26")
log.info("entered27")
log.info("entered28")
{ log.info("entered29")
log.info("entered30")
if(otherSubtasks.every{it.getStatus().getName() == "Prioritized"}){
log.info("entered31")
{ log.info("entered32")
log.info("entered33")
log.info("entered34")
{ log.info("entered35")
log.info("entered36")
if(otherSubtasks.every{it.getStatus().getName() == "Cancelled"}){
log.info("entered37")
Please guide further on how can I achieve the above transition logic using the mentioned Post-Function. It would be a great help and learning for me using groovy.
Have you managed to find a solution for this?
Thank you and Kind regards,
Ram
