×I have transition condition on the move between backlog status and open status only allowing the scrum master to execute this. This is great for stories, but I want engineers to be able to create and move sub-tasks without the condition between backlog and open. Thoughts?
Hi @DSell - Maybe create a second transition from Backlog to Open with a Condition where the issuetype = Sub-task.
You would add a condition for Value field
Then choose Issue Type from the dropdown
Change operator to =
the type in the exact name of the issue type - probably Sub-task, but you should double check that.
Click Add
Then Publish the workflow.
Ah, I missed that you were using Jira Server. Anyway, glad you got it working. :-)
