Transition issue when updated the comment field.
Fernando Passos
I need transition issue when updated the comment field its possible?
I'm using the Automation Roles - JIRA WorkFlow Toolbox or Script Runner.
Help me please?
M Amine
Yes it is possible. Here is how with Scriptrunner :
  1. Add a Script listener (Custom Listener)
  2. Listen to the event "Issue Commented"
  3. Add your groovy code to transition the issue (here is some help)
Thorsten Letschert _Decadis AG_
Hi @Fernando Passos ,
with regard to Jira Workflow Toolbox, an automation rule as easy as
community_transition-on-comment.PNGshould do the trick.
  • Create a new automation rule
  • Choose an Issue event - Issue commented trigger (or Issue updated if that's what you're after)
  • add a Transition issue action with the transition of interest
If you need more business-logic, you can obviously extend this rule by additional conditions.
Get more information related to getting started with automation rules here.
Cheers
Thorsten
SERVER
