Trick to intercept comment on jira issue with JJupin for notification
Tim Full March 18, 2014
I've successfully integrated JJupin to be invoked as a post function on a transition, but I'd also like to intercept a comment add for notification. The comment button is not a transition, so I'm not sure how I set the hook to be able to create the notification.
Suggestions?
I think I figured it out. I'll try configuring the SIL Listener from the Kepler Admin page. Looks like what I was looking for.
eric anier
July 16, 2014
Hi Tim,
can you share your solution on this?
Tim Full July 16, 2014
You need to use the SIL Listener function which you can configure from the Jira Admin -> Kepler General Parameters dialog. There is a listener available for all the standard events just like the Jira notification implementation. You can set up a listener for 'issues commented' and have a SIL script executed just like out of the transitions.
Register now
