Trigger global loop transition from Automation
Pieter Wouter Hartog
March 21, 2024
How can trigger a global loop transaction from Automation?
I created a global loop transition that executes a scriptrunner script (it clones issues in a certain way). However, I'm running into timeout issues, there is a 240s max time that Jira Cloud imposes on each script execution.
Now I'm trying to split up the script into a smaller task and let Jira Automation to the main loop through the issues I'm trying to process/clone. For that, I would need to trigger a global loop transition from Jira Automation.
When I look at the Automation action of 'Transition Issue', I do see the option for 'Same Status (Loop)', but not for a specific transition.
Trudy Claspill
Hello @Pieter Wouter Hartog
Did you review the information provided by this link in the Transition Issue action configuration?
In the answer on the following post there is an example:
https://community.atlassian.com/t5/Marketplace-Apps-Integrations/Choosing-a-specific-transition-when-I-have-multiple-going-to-the/qaq-p/2012258
