Troubles with wiki style renderer for custom field text field
Vladimir Stechenko
June 16, 2015
Hi, i have a custom field
it is Text Field, and according to https://confluence.atlassian.com/display/JIRA/Configuring+Renderers - this type is supported by Wiki Style Renderers
Renderer for this tickets is set as
However,  somehow it does not support wiki syntax while Description field does(same text for 2 fields in 1 ticket)
Matheus Fernandes
June 17, 2015
Vladimir,
It looks as this custom field is configured to use the Default Text Renderer. To configure this, simply navigate to Administration » Projects » "Your project", select Fields and edit the Field Configuration for this issue type.
You'll see a "Renderer" option next to the custom field name. smile
Matheus
Vladimir Stechenko
June 17, 2015
thanks
Kubilay Onur Gungor October 5, 2015
it seems does not work custom fields. there are options only for default fields.
Shalvika Sood November 11, 2016
It's applicable for custom fields as well. You have to edit the default field configuration and change the renderer type as mentioned above
Jesse
September 3, 2018
Did that - Still not working.
Tomasz Grochowski
September 24, 2018
There are two ways to configure that.
1. Go to general Jira settings and change renderer config. I did it and somehow id does not work.
2. Go first to your project and in project settings go to Fields configuration and there is renderer config. This way worked in my cane.
Like # people like this
Sébastien Richard
March 12, 2019
Here is what I've done for a new custom field name "To Do" :
Project Settings >> Fields >> Edit Default Field Configuration >> Renderers (for my custom field) >> Active Renderer = Wiki Style Renderer
My new custom field appears in my screen but Wiki Style Renderer does not work.
Thanks in advance for your help.
Björn Osbahr
March 15, 2019
Yep, same here. If I click inside such a field the default text renderer applies.
Erik Menkhorst
March 25, 2019
Same applies for me unfortunately ... :(
Brett Wyrick
@Tomasz Grochowski's reply above, particularly #2, worked for me.
Oddly, I had to go to the Project that I was working on, go to Settings, then go to "Fields". Then I pressed the pencil icon near the top right, then found my field to have "Default Text Renderer" on it, though I had changed it on the "Screens" setting. I changed it to "Wiki Markup Editor" (or whatever it is) and now it's working. Insert shrug emoji.
Clifton Foster
Confirmed. Just setting it in the Global Settings does not change it in the Project. You have to go to the Project and change the setting as explained above by Brett Wyrick and Tomasz Grochowski.
Like Brett Wyrick likes this
Pavel Bryukhanov
Despite this is marked as "Solved", I spent quite a few hours trying to understand how to fix this.
Here a video tutorial on how actually do it in 5 minutes...
https://youtu.be/QCNHPy88iKA
Enjoy.
andrés
Life saver, thanks!
Jack Garrod December 14, 2020
Knight this man!
Arpit Joshi
February 26, 2020
Tomasz Grochowski's Second option worked for me. Thank you.
