Trying to clean up custom fields from a migration
Mike Ruthven January 31, 2025
Hi there!
Our company was a spin out from a much larger company, and when our Jira project was migrated out, a great deal of information that existed in the larger company's Jira cloud projects came with it. I've been cleaning up, but currently am faced with 932 custom fields in our system, of which we need...possibly zero, honestly.
I'm comfortable using the REST API and have a script that shows me the list of custom fields, but that only shows 29 custom fields. I am an org-admin for our site, and have tried calling with a personal token, or one created via the organization settings page, same results. I am assuming I'm just missing something obvious that is limiting what the call returns. Any help is appreciated!
Mike
Vishal Biyani
January 31, 2025
@Mike Ruthven
have you run this end point to get the list of fields?
https://your-cloud-instance.atlassian.net/rest/api/3/field
Once you have identified the fields you should be able to use below endpoint to delete the custom fields
url = "https://your-domain.atlassian.net/rest/api/3/field/{id}"
Refer link: The Jira Cloud platform REST API
Mike Ruthven February 3, 2025
Hey Vishal,
I have run that endpoint, yes. It only returns 29 fields, but the UI shows me > 900. So I'm trying to figure out what permissions I would be missing (I am an org admin) that would not return all 900+. I realize there is pagination but at 29 that is not the boundary that I am hitting I don't believe.
Vishal Biyani
February 3, 2025
@Mike Ruthven
as per documentation, one of the reasons why the fields are not returned is below
is it possible that some of the fields are not mapped to any project?
Mike Ruthven February 4, 2025
Oh. It hadn't even occurred to me to read it that way. That is almost certainly the problem. OK. I kind of get the feeling I'm going to have to one-at-a-time delete them from the UI.
Petru Simion _Simitech Ltd__
@Mike Ruthven ,
Cleaning up custom fields can be a daunting task. You need to determine if they're used anywhere, identify redundant fields with similar meanings, and simplify by consolidating multiple fields into one. Custom fields can be embedded in various places, including:
- Screens (create, edit, and view)
- Workflows, where fields are used in actions, transitions, or other workflow steps
Manual searching is extremely time-consuming and prone to errors. An automated solution is essential to efficiently identify and optimize custom fields
If you are open to using apps, you can use Fields Dashboard for Jira , an app released by our company.
Search and filter custom fields across your organization's projects with precision. Choose to:
- Search all fields in all projects
- Filter by specific projects and fields
Analyze field usage from two distinct perspectives:
1. Screen Scheme Perspective: View how fields are utilized in projects through their inclusion in create, edit, and view screens.
2. Workflow Scheme Perspective: Examine how fields are employed in projects as part of screens used by workflow actions.
Petru
Hi Petru,
I will have a look at this tool. The issue is less trying to analyze the custom fields, and more the ability to just remove them in bulk. We exported a very simple project from our parent company's instance when we were spun out, and we seem to have gotten all the custom fields from all of their projects in our instance. I know that we are only using a handful of fields, and the proliferation of custom fields has been zero at the new company, so I can almost certainly just remove _all_ custom fields, and then could clean up any mess afterwards, though this would be a better way to skip that cleanup step.
Valerie Knapp
January 31, 2025 edited
Hi @Mike Ruthven , welcome to the Atlassian Community and thanks for your question.
I refer you to an article by my fellow community leader, @Darryl Lee
https://community.atlassian.com/t5/Jira-articles/Tidying-Up-Jira/ba-p/1748466
What I typically recommend after a migration is to install the free trial of an app like Optimizer https://marketplace.atlassian.com/apps/1217194/optimizer-for-jira?tab=overview&hosting=cloud  or https://marketplace.atlassian.com/apps/6398/jira-command-line-interface-cli?hosting=cloud&tab=overview , which can help you identify and remove in bulk things like inactive workflows, unused screens and custom fields.
Anyway, please read the article and check out the apps to see if they help you.
If you have more questions or doubts, please let us know.
Best of luck!
Hi Valerie,
Thanks for the reply! The article you linked seems to be geared for a workspace that has grown a bit too organically over time, where I'm in "spun out from large company, inherited a huge amount of customization from that large company, don't want _any_ of it." I have installed the CLI and am getting permission issues, as running the `getFieldList` command gives me a 401. I am an org admin in this workspace, so I'm struggling with what I might have done incorrectly when generating my access token.
Register Now
