  • Community
  • Q&A
  • Jira
  • Questions
  • Trying to get a field to hidden or not hidden depending on the selection of a Select List (Single)
Aaron Andrade
We are trying to make it where A field is hidden on a screen unless one of the two highlighted choices are picked:
Here is the code that I used in behaviour:
Tinker Fadoua
@Aaron Andrade
Where are you adding the script?
Because for me it worked when I added my script under behaviours.
Best,
Fadoua
Aaron Andrade
That's where I am adding them. Is mapping needed? I haven't used the behaviours before so I don't know if I am missing something.
Tinker Fadoua
You need to add the script to the field you are making selections on "customfield_11011"
Aaron Andrade
It still hasn't worked, but I am running a re-index since fields have been added and the behaviour to see if that will help. If doesn't I will share a screen shot of how I have the behaviour setup.
Like Tinker Fadoua likes this
Aaron Andrade
Still didn't work. Here is how I have the behaviour setup.
Tinker Fadoua
Please add an initializer
define both dropdown
add a condition getActionName == "Create"
dropdownfield.setFormValue(null)
Tinker Fadoua
Sorry now I see what you are trying to achieve.
I was under the impression you are hiding a field based on the option selected from a different field which is not the case
I am little bit confused. Sorry if you can provide more details
Aaron Andrade
So what I am trying to do is make "customfield_19915" visible only when one of the two highlighted options in the original post are selected. Then if any of the other options are selected then the field stays hidden. The reason for this is if the one of those two options are selected then the client needs to be notified and if not they don't.
Tinker Fadoua
Sorry wrong post.
Ok @Aaron Andrade then your script is wrong.
Try Carmen's solution as suggested below, it is what I did in my script
https://community.atlassian.com/t5/Adaptavist-questions/Show-Hide-custom-field-based-another-another-field-value/qaq-p/963847
Tinker Fadoua
On your script you are getting a field Id and the same field you are getting its value which I think is wrong. However I am not a Groovy expert.
Like Aaron Andrade likes this
Aaron Andrade
Thank you! I will give that code a try and see if we can get it to work. Thank you for all the help I appreciate it.
Aaron Andrade
Using the forum post you sent me and some documentation for scriptrunner I got the code to work see below the new code:
Tinker Fadoua
It always makes my day when I get this kind of confirmations. Thank you for the update @Aaron Andrade !
If satisfied with the help provided please don't forget to accept my answer.
Best,
Fadoua
Aaron Andrade
Would happen to know how to change the code to make it work for a multiselect list or know where to point me?
Tinker Fadoua
Let me check then get back to you
Aaron Andrade
Thank you!!
Tinker Fadoua
@Aaron Andrade
Why don't you try and to your if condition if (A == x && A == y) {
  script goes here
The same one you had earlier with the &&
